KO4OO
Thurman Williams Jr
6400M and Q5 I have several HF rigs hooked together with a Alpha Delta switch box. one being my 6400M.. question?? when using my 6400M and the Q5 transverter. Will it be safe to transmit with one of my other HF rig with the 6400M on using it with a slice open to monitor 2 m with the transverter without taking out the front end .... Alpha Delta says 70db of isolation unused selections are switch to ground. Still worried when I'm transmitting with my Yaesu I'll take out the front end of the flexradio if it's on at the same time monitoring 2m with the transverter.. anyone have any thoughts Jr. KO4OO
If you have 70 db of isolation, your Flex should be safe ( unless something fails and the isolation is no longer 70db ).
AL, K0VM
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
