flex6500 eq doesnt work on 3.1.8
Robert Brooks
Upgraded flex 6500 to 3.1.8 and when using multi flex the EQ's do not function if more than 1 radio is connected via multi flex.
Only guessing... There is an confirmed issue with the receiver EQ using more than one slice, could it be the same thing you see? Try to change mode i.e. go from LSB->CW->LSB and see if the EQ do kick in.
TX or RX not working?
just checked here and at least with a windows slice up and a IOS slice up the RX EQ works on both devices here.
I haven't tested the TX EQ but have not noticed anyone complaining about my TX audio going wacko if I have someone connect in to the Radio.
BUT I always do a hard reset anytime I do a firmware upgrade.
good luck
73's
Bret
WX7Y
This is what it sounds like to me too. Please let us know if this suggestion helps Mr. Brooks.0
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
