Maestro not loading any Mic profile when it starts up or I change bands.
Steven Hess
When I start my A model Maestro I have no transmit audio. I have to go to the Mic profiles and load a profile. That enables it. When I change bands it does the same thing. Do I have a setting somewhere I've made that is casuing this? Rig is a 6300.
Check your battery. The internal Tablet computer drains the battery even of the Maestro has a power supply.0
This should answer all your questions: https://www.flexradio.com/downloads/smartsdr-profiles-how-to-guide-pdf/0
It's interesting that this is new behavior I just noticed. Didn't do this before. Admittedly I have not used the Maestro much. I'm suspecting I made a change per band that impacted the Maestro in SmartSDR.
are you running any logging, or digital programs on a computer with CAT running on the computer that is connected to the radio by chance?
CAT is not in use. DAX is not in use.
- 650 The Flea Market
- 152 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
