Cw Tx distortion
SA7AKE
Look at pictures, the TX cw signal looks very wide with distortion. Looks like this in 6, 10 and 17m. Can anyone explain why it looks like this? 73 Jonas SA7AKE
This is 20m, same antenna
It looks like you are zoomed in at different levels. On 20M you are looking at a few kHz. On the other bands you are looking at tens of kHz. What you are seeing is the keying artifacts. As an experiment, transmit into a dummy load and watch a string of dots. Then set the tune power to the same value as transmit power and click the tune button. You will see far fewer spurs, because a steady carrier has no keying artifacts. Try with the panadapter zoomed farther out. to see more artifacts.
Len, KD0RC
One thing to be careful of... I don't know how accurate this display is in showing transmitter spurs. If you turn on FDX (full duplex) and transmit into a dummy load, you can see how the radio actually hears the transmitted signal. On my 6400, I don't see any spurs at all even though I have a very similar display to yours when not in FDX.
Len
Yes the monitored transmit can look really dirty. Best to use the dummy load method and full duplex.0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
