ALS-600 with RJ-USB6000 cable problem. Amm WOn't turn on Cable not recognized.
Steven Hess
OK. I got a new ALS-600 and got the MFJ Flex specific USB cable plugged it in.
Then the amp shut off. I had configured the USB cable BCD active high.
I removed the USB cable from the USB devices window before I unplugged it.
Now my 6300 will not recognize the USB cable when plugged in.
Nor will my ALS-600 power on despite all my efforts.
Any Ideas of what I should try? Hope I didn't **** my new AMP.
There have been several posts here recently about these cables being mis-wired. Do a search. If you can't power-up the amp with the able disconnected, it will probably need a trip back to Mississippi.1
That would be a bummer. I'm hoping I can some how reset the ALS-600. Power supply is making power Plugging the USB cable into a PC and it's not recognized so I'm thinking it's dead.
iS IT A ALS 606 OR ALS600? The als600 needs the ar500 between radio and amp with the other two cables going to amp
ALS-600
Then you need an ARI-500 (AR-eye) between the 6300 and the 600. If you plugged the USB cable directly into the amp you likely fried the cable.
https://mfjenterprises.com/products/ari-500?_pos=1&_sid=dca9c3448&_ss=r
Yea. I talked to Ameritron. Fried the cable and blew 2 amp fast **** fuse in the Power Supply
You need the ARI500 and an rca cable from TX1 to relay. And you will find out that neither the operate / standby switch on the amp or the ARI500 is functional with that setup.0
- 384 Community Topics
- 649 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
