N1MM Locks-Up when trying to "New Log in Database: XXXXXX"
Mike Visich
Trying to get ready for CQ WPX SSB this weekend with N1MM. I create a NEW DATABASE, and then try to create a LOG in that database and BOOM! N1MM just locks up!
It's still running - taking up ~3% of the CPU but frozen. Like a window is open somewhere but not available OR it's trying to open a window somewhere and not able to...
Otherwise, N1MM works great. Before I try to create a new LOG, N1MM is able to control the FLEX by changing bands and tracking frequencies in SO2R mode. Amazing.
Any suggestions? Would really like to do that contest since I'm in lock-down.
73 Mike
NG1M
73 Mike
NG1M
Mike,
Close N1MM. If it is still running, hit Alt+F4. Now, restart N1MM and it should open with the database you just created. Try creating a new log again. If that doesn't work, see if you can create a WPX log in the previous database, one that you know works.
73, Ted W4NZ0 -
THANK YOU!!!
THANK YOU!!!
Never used ALT F4 before, but that opened the NEW LOG window!
Any advice on setting up a VOICE KEYER with N1MM and a FLEX 6400?
Again, THANK YOU.
73 Mike NG1M0 -
Mike, the how-to on setting up the voice keying between your Flex and N1MM is contained in the document available here:
https://www.flexradio.com/downloads/flex-6700-so2r-configuration-n1mm/
73, Ted W4NZ
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
