How to find lost factory setting profile for FHM-2 Mic?
Francesco Doenz
I inadvertently tinkered with the FHM-2 factory mic profile...sorry! Where can I find the factory settings again?
As always many thanks to the community for your help and support!
There may be other methods.....one way is to do a "factory reset", shut down, hold the power on button for five seconds until you see the button turn white. All of the default profiles are loaded as a result. As usual, be sure to backup your profiles, as those will be lost in the process and must be imported from the saved file.
Alan
WA9WUD0 -
Yes it's the only way I know, but it's a lot of work to restore everything for a newbie like me, I was thinking the settings of the EQ numbers should be easy to find somewhere??0
Did you save the profiles to your PC using Profile manager. If so you can use "Inport/Export Profiles" function to retrieve it. I did not save the hand mic profiles, so i cant give you the default EQ settings. I only saved my custom mic settings.
Gayle K0FLY
No, I did not save them on PC because I was thinking that changing a profile would not erase the factory setting...you always learn the hard way...I hope someone will step in with the factory EQ numbers!0
Default FHM-2
63= 0
125= 1
250= 0
500= 0
1K= 1
2K= 2
4K=3
8K=2
Wouaw!! Many many thanks for stepping in!!!0
Your welcome, but keep in mind, using a Flex without saving your profiles is a bad idea. It saves people from so many problems.
Yes, As I said you learn the hard way but I must say that the fora of flexradio are extraordinarily reactive compared to fora in other domains, it's may be a trait of hamradio hobbyists!0
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
