Can one have multiple panadapters across multiple monitors
Jeremy - W2JG
Is it possible to display multiple panadapters across multiple computer monitors? In this way, one could display slices A-D on the first panadapter on the first computer monitor then have slices E-H on the second panadapter on the second computer monitor. If this is possible, how does one do it?
If this is not possible, do people agree this would be a useful feature?
Thank you for your input and assistance!
Jeremy
W2JG
Jeremy
W2JG
What version are you running? You can pop a slice out, move, and resize it anywhere you want in the newer versions. I forget which version that started in. There's a third little box next to the close and minimize boxes in the upper right hand slice corner.
Bob, WK2Y
I am running the latest version 3 revision. I did not see this in the documentation., nor the community forum. I wanted to know before spending the money for additional monitors.
Thank You for your help Bob!0 -
You can have to many monitors. :-)
Flex 6600M version 2.5.1. Note that one panadapter will always remain in the main window. You can also pop out the radio control panel and move it around. I have three monitors and use this feature.1 -
Thanks for the picture Joe!0
Arghh. That should have been, "You can't have too many monitors!!" ( I have 3 and would like 4.)
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
