Welcome to the FlexRadio Community!  Please review the new Community Rules and other important new Community information on the Message Board.
usb to firewire adapter
                    Paul Vitty
                    i have just got flex 3000 but my pc is bran new also but it dosent have a firewire connection can i just use usb to firewire adapter thanks
            I don't think that there is a Firewire to USB that works with the FLEX 3000 mainly because of the data speed and you will need a Card that Plugs into the motherboard preferably with a TI chip set, hopefully your new computer has expansion ports that can accept a expansion card.
 73's and good luck
 Bret
 WX7Y1
            No, it will not work. If you look around you can find a fire wire card for your computer. I bought a PCIE card for my new machine and it works fine.
            do anyone know what card i want thank u
            i dont have clue really so i need a fire card ?
            What does it say under the slot,,it looks like an PCI slot
 Here is the different ones
            Looks like you have both a pci and a pcie you can use. look at my pictures. the pcie is the short one. the one you want are blue. Amazon will have cards for both.
            It looks like you have available PCI and PCIe slots for usage of a firewire card.
 I would recommend this card:
 https://www.amazon.com/SIIG-FireWire-2-Port-PCIe-NN-E20012-S2/dp/B000G6U8VY/ref=sr_1_1?keywords=siig+1394a&qid=1584725794&sr=8-1
            i got this bill thank u for all help
            thank u
            Glad to help Paul
            The Flex-3000 is ideal for fieldday or EMCOMM use as you can put a notebook on top the TRX. Both the Panasonic CF-52 and thE GETAC S400 semirugged notebooks have firewire connectors that work with the Flex-3000. You can get them in a good used condition.0
            I had semi success with a converter..usb to firewire. Its worth a shot otherwise u need a card and a spare slot. Give converter a shot first.0
            An adapter? It will just not work if the 1394 bus is being emulated by a different physical interface. This is why we gave advice to get a proper card for his slots. They are not expensive.
            Let me put this issue to reset. A native Firewire 400/800 interface is required. In general, the VIA and TI chipset based Firewire adapters work the best for Win10. Not all Firewire adapters can handle the high data throughput that is required for the FLEX-5000 and FLEX-3000.0
- 355 Community Topics
- 619 The Flea Market
- 8K Software
- 15 SmartSDR+
- 6.3K SmartSDR for Windows
- 414 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 221 FLEX-8000 Signature Series
- 927 Maestro
- 900 Genius Products
- 458 Power Genius XL Amplifier
- 325 Tuner Genius XL
- 117 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 980 Third-Party Software
