Filter Spots from VE7CC to NA using Slice Master de W8LMG
W8LMG
W8LMG Member ✭✭
edited March 2020 in FLEX-6000 Signature Series
I am using Slice Master and would like to filter the spots from VE7CC to see only those from NA. Can this be done if is so can someone post the proper setup for it. Thanks and 73
  • Dave Garber
    Dave Garber Member ✭✭
    edited March 2020
    if it were me using ve7cc, i would be logging on to their cluster, with there software and set filters that way, then S/M should follow, if you log on the same way
  • W8LMG
    W8LMG Member ✭✭
    edited March 2020
    Thanks for the response Dave. I did some additional research and found a good solution that put the VE7CC spots, as filtered, from Logger32 onto SmartSdr.
    https://groups.io/g/hamlogger/topic/dx_spots_show_in_flex/22891556?20,0,0,0::recentpostdate%2Fsticky...
    In addition to the information provided, you must go to your SmartSDR Cat and create a UDP Port 12061. Once this is complete the spots will be appear on the open Slice A.
    This does not use or require SliceMaster.
    Mac W8LMG
  • Dave Garber
    edited March 2020
    i get them on my screen via n3fjp being connected to the cluster...
