6400 waterfall not moving when transmitting
Jim Couture
My waterfall stopped moving during transmit it use to move while transmitting.
Have you done anything to correct it?
mine never has moved0
If it never moves, how can you see you TX signal when it is selected?
Under, settings, radio setup,,,under TX select show TX in waterfall.. otherwise the waterfall stops on TX.
you referring to the noise floor on the top half0
No, the waterfall, should move and show your TX if selected to show as I described.
That fixed it. I lost some settings after a power blink so that must have switched off.
- 650 The Flea Market
- 152 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
