6400 waterfall not moving when transmitting
My waterfall stopped moving during transmit it use to move while transmitting.
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited March 2020
    Have you done anything to correct it?
  • KI4P
    KI4P Member ✭✭
    edited May 2020
    mine never has moved
  • Bill -VA3WTB
    edited March 2020
    If it never moves, how can you see you TX signal when it is selected?
  • Bill -VA3WTB
    edited March 2020
    Under, settings, radio setup,,,under TX  select  show TX in waterfall..  otherwise the waterfall stops on TX.
  • KI4P
    KI4P Member ✭✭
    edited May 2020
    you referring to the noise floor on the top half
  • Bill -VA3WTB
    edited March 2020
    No, the waterfall, should move and show your TX if selected to show as I described.
  • Jim Couture
    Jim Couture Member
    edited March 2020
    That fixed it. I lost some settings after a power blink so that must have switched off.
