Can I use a TRRS headphone cable in the 6400M headphone TRS jack?
Does that apply to this situation as well, or can I use the TRRS cable and simply lose the mic?
Tnx es 73 de Mike N2YBB
I would avoid it and see if Bose has an adaptor to convert to TRS. I say that only because there are several wirings for TRRS that have the ground in different locations. Unless another Flex owner has already tried it. Anyone?0
I agree
TRRS will not work. That is for phones and tablets. You will need an adapter to split out the headphones and mic and connect that to the appropriate 1.8" TRS connectors on the back of the radio.0
Tim - I believe this should work, right? Its TRRS to TRS. I'd expect the back of the 6400M would accept the Phone and MIC.
https://www.amazon.com/gp/product/B07HXY9LV8/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
I can confirm this aftermarket MIC boom works with my Bose QC25. The package also includes the TRRS splitter to separate out the MIC and PHONEs.
Even then you can’t just plug in the MIC into the back of the Flexradio, you have to enable BIAS and wire your own TRS adapter for the MIC into the back of the Flexradio using this circuit published by Dale K4DG. When you solder make sure TIP from the radio connected to TIP and RING on the MIC, and short RING/SLEEVE from the radio to sleeve on the MIC:
Dales original post has a lot of good detail. The circuit also works with the KOSS SB45 headset with integrated MIC boom.
https://community.flexradio.com/discussion/comment/20586161
- 324 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 259 SmartSDR for iOS
- 246 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 149 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 863 Genius Products
- 305 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 135 Contesting
- 714 Peripherals & Station Integration
- 134 Amateur Radio Interests
- 936 Third-Party Software
