Oscar-100 - Band Limits
Roland HB9VQQ
I am using my Flex 6600 and a Up/Down Transverter for Oscar-100 . Is there a way to inhibit TX when out of Band ?
Roland
Roland
I think if you use one of the Transverter jacks on the radio the radio will cover what you need when the transverter settings are set correctly on the radio.
Bret0 -
My read of the Flex Hardware Reference Manual, Section 4.1, "Transverter Output Port", looks like it can TX 100 kHz to 54 MHZ. This is necessary to allow the transverters to operate throughout their band ranges.
In my case, I use the USB BIT relay option to direct the PTT to the various transverters based on the band and frequency range.
Alan
WA9WUD0 -
I was looking for a SSDR setting to limit the TX Range on QO-100. You cannot configure the limits on the XVTR setting.
Roland0
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
