Oscar-100 - Band Limits
Roland HB9VQQ
Roland HB9VQQ Member ✭✭
edited June 2020 in New Ideas
I am using my Flex 6600 and a Up/Down Transverter for Oscar-100 . Is there a way to inhibit TX when out of Band ?
Roland
  • WX7Y
    WX7Y Member ✭✭✭✭
    edited June 2020
    I think if you use one of the Transverter jacks on the radio the radio will cover what you need when the transverter settings are set correctly on the radio.
    Bret
  • Alan
    Alan Member ✭✭✭✭
    edited March 2020
    My read of the Flex Hardware Reference Manual, Section 4.1, "Transverter Output Port", looks like it can TX 100 kHz to 54 MHZ.   This is necessary to allow the transverters to operate throughout their band ranges.
    In my case, I use the USB BIT relay option to direct the PTT to the various transverters based on the band and frequency range.
    Alan
    WA9WUD
  • Roland HB9VQQ
    edited March 2020
    I was looking for a SSDR setting to limit the TX Range on QO-100. You cannot configure the limits on the XVTR setting.
    Roland
