rig sharing with a GUI client
Jim Shaffer
I'm trying to implement rig sharing with my GUIClient using FlexLib Version 3.1.7. I have things working the way I want, except I'm not sure how to handle transmitting.
As I understand it, with SmartSDR, both users can transmit, but only one at a time.
I'd like to limit transmitting to just one user, if possible. I'm not sure how to do this. It doesn't seem to work well if I set IsTransmitSlice off for all the slices for the nontransmit user.
I also don't really understand PTTSource and SetLocalPTTForGuiClient().
Can someone give me some pointers?
Jim,
Here's how things were designed. Each GUI client has it's own designation of which Slice is the transmit Slice. This means from a radio point of view, there are multiple Transmit Slices at any given point in time. As a result, we do a Just In Time (JIT) switch when a client keys the radio to decide which Slice to use as the Transmit context. This decision gets made based on the origin of the PTT signal. If the PTT is coming from a hardware input to the radio (like a footswitch), then we will automatically use the Local PTT client's TX Slice. If the PTT is a software PTT signal (xmit command), then we will use the Transmit Slice for the client that sent the command.
Does that help to sort things out? I trust that you've seen the SmartSDR v3.0 Migration Guide. If not, it may be worth having as a reference.
I've discovered that if I issue a Radio.SetLocalPTTForGuiClient(), that updates the client's GuiClient, notifying the other host. Is that what you do with SmartSDR? If so, when do you do it, and how do you know to do it?
Setting the Local PTT sets which GUI Client to use for the transmit context when using a hardware PTT plugged into the radio. There are some more details spelled out in the migration guide linked above, but in general, you would set the Local PTT to the client that is near the radio so that when you key it, the correct client context is used.0
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
