Shutting Power to the FLEX-6400 from my Astron
K5BGP
Coming from a Kenwood TS-590S where I could just flip the switch on the Astron and **** power to the radio... can I do the same thing with my FLEX-6400? Or do I need to do a "proper" shutdown by pressing the green power icon on the radio?
Applying or removing voltage from the power supply is generally not preferred for any electronics, due to the risk of a quick inrush on startup, or undervoltage effects on shutdown. Some rigs keep some circuits running, even while off. That said, you -can- shut down from the power supply, but the TCXO won’t maintain accuracy, and the rig will throw an error message. Normally, not serious issues, but worth avoiding if you can. Power down like you would your PC or other expensive digital electronics.0
Turning off the primary power on the FLEX without an orderly shutdown I/E the ICON power button can cause some issues with memory, and as George stated the TCXO will have to stabilize each time you turn the radio on.
If you have the GPS option as do I stand by mode keeps it turned on and accuracy maintained. Otherwise frequency accuracy is not maintained until it has stabilized and locked back on to the birds, this takes about ten minuets from a cold start.
In my case my 6400 is remotely located on a mountain top repeater site I float the power supply across a battery first as a power back up second as a spike filter. I use the remote on jack to turn it on and standby with a Micro bit web switch. If your worried about power surges I would also suggest a whole house surge arrester that can be installed by an licensed electrician. I have one at home and the remote site. Hope this helps
Steve AG4SO
Thanks for the advice. It mirrors what I suspected. Honestly, I haven't shut the radio off in at least a week, and would like to keep it powered up (that's the point of SDR -- operate anywhere).
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
