What is this?
Steve G1XOW
I've noticed a sudden jump in noise level on 15m over the last few days. So, I started to investigate and it looks like it may be internally generated.
I've pulled the plugs on all cables to 6400 except the ethernet and power cable, and it is still there! The PSU is a linear design, not an SMPS. The Ethernet is cat6 directly to the PC and this has not changed for nearly a year.
In-band on 15m the noise level has gone up by about 1.5 s-point (now showing about S3-4) even with no antenna connected. However, I notice that out of band there is a massive bulge of noise -90dBm just above the 15m band....and this still is with NO ANTENNA connected whatsoever. Take a look at the pics.
I have also done a cold reset on the radio and removed and reinstalled the latest SSDR app just in case. What I am seeing here? The radio is just a year old. Do I have a problem with it?
73 de Steve G1XOW
73 de Steve G1XOW
You are not alone Steve I have the same problem. Made 15M un-operatable on the weekend. A fellow ham to the west of me had the experienced the same. Going to try and track it down today.0
Does it also occur with a dummy load on the antenna connection? (with the line terminated at 50 Ohms, that is)
Any new electronics added to your house or neighborhood?
I could see my furnace fan's variable speed drive (yes, even with the antenna disconnected) until I added filters to the motor drive.
Looks like the preselector is filtering out a good chunk of it.. looks like an external nose source
Check your computer's power supply. It may have lost the capacitors on the line filter.
Does the WNB change anything?
Duanne, exactly the same on open. short or 50 ohm dummy load to the antenna socket. Also tried the other sockets for XVTR and RXA...all the same.
The signal would have to be pretty massive for it to be anything external generating -82dBm in to a short circuited PL259 on the radio. So I assume it must be internal to the radio.
Also, nothing show at all in wide mode (when zoomed out) but when showing the whole of 15m plus a bit then the image is what you get.
Bill,,
Yes WNB kills is but so does zooming out to "wide mode". Nothing shows at all in wide mode. But when showing the whole of 15m (with band pass engaged) then the image is what you get....even with -8dB of attenuation and the PL259 shorted.0 -
It still seems to be getting noise into the radio, even without an antenna. That is possible.
Do you have another PS to test with? I wonder if the PS is emitting a noise on that band.
Not often talked about is the radio ground! I have a excellent ground system, 1.1 Ohms ground conductivity. That can make a big difference to how things operate in the shack... Flex has a good reason top have a ground connection on the rear of the radio. Also checking the Shack Ground at least once every spring and fall is like changing batteries twice a year in your smoke detectors... Another important thing to do, If you are TRAINED, and be safe, Is to check your circuit breaker box to be sure everything is tight, more with Aluminum Wire then copper, but I check mine at least once a year.. Let us know what your final fix is!!
Robert0 -
@Steve, it does sound like the noise source is external even though the antenna is disconnected. Rather than hashing this out on the Community, I'd recommend you open a HelpDesk ticket so that one of our engineers can rule out anything wrong with the radio.0
Hi All,
Just wanted to check in on this and let everyone know where we are, and to help you avoid wasting time on this. As suspected all along the problem is indeed a defect for Flex to fix. Thankfully it looks like a software defect rather than another hardware warranty issue.
I've spent nearly 2 man-days chasing this ghost of fake interference. I have ripped my shack to bits and re-engineered almost every aspect of my station, new cables, local area samples of noise measurements, swapping PSUs, switching computers, new GPU, using other peoples radios for corroboration, isolating my shack from the mains, installing and reinstalling software, resetting the radio, profiles etc etc simply to prove what I already knew to be true.
The upshot is that this is a "known" (known to FRS that is) internal defect within the radio software, and obviously not local interference.
This issue has been logged as defect number: 6964
3 -
Sorry for you waste of time, there is no radio worth that much time being wasted no matter what brand. This is just really sad .... but it is what it is and wont change in the future either ...0
Curious, how do you know it is a logged defect? Where did you find this?
The information was provided to him by FlexRadio technical support.1
And here is another example of "fake noise" being produced on a Flex radio. This time it's on the 10m band. Don't worry if you see something like this, it isn't actually faulty it was designed that way!0
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 247 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
