Output power control
Andrew - G0RVM
Andrew - G0RVM Member ✭✭
edited March 2020 in SmartSDR for Windows
The Power output slider on SSDR (2.6.1) is great and gives granular control over a 100W range (Flex-6600).  At a setting of 1 my SPE amplifier generates about 120W; at 2 it generates about 380W.  I would like to have increased granularity of control when using CW so a higher setting - perhaps 5 or 10 - results in 380W or thereabouts.  Put another way, I'd like to configure the upper limit of the SSDR Power output slider to a value - perhaps 50W - and distribute that across the entire range of the slider control.  Hope that makes sence.
I don’t think the upper limit of the SSDR Power control is configurable so the only way I can think to achieve greater control is to add an attenuator in the transmission line between the Flex and the amplifier.  The problem with this approach is that with a single antenna the transmit/recieve path is shared.  Thus the attenuator needs to be removed from the receive path, preferably automatically via transmit/receive switching.
Just wondering if I'm missing something? Perhaps SSDR can be configured differently?
Andrew
G0RVM
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited January 2020
    Scaling the power output control to better tailor driving a linear amplifier is a great idea. Maybe it can be implemented in future updates.'
    Perhaps something like this:
    0-25
    0-50
    0-75
    0-100
    Jim, K6QE
  • ctate243
    ctate243 Member ✭✭
    edited January 2020
    "I don’t think the upper limit of the SSDR Power control is configurable "
    Settings >> Radio Setup >> TX tab >> Max power  Change 100 to your desired max output power.
  • Dwayne_AB6A
    Dwayne_AB6A Member ✭✭
    edited January 2020
    When I ordered my amp to match my 6600, I was able to specify the input range and chose 50W -> 1000W vs 5W -> 1000W and other options. Learning more about my amp, I found it is using the A1000-100-11X 10dB pad https://www.barryind.com/pdf/Attenuator/Power_Flange/A1000-100-11X.pdf to control input attenuation. Worst case (and a nice Sunday project) is a small circuit that incorporates a pad mounted to a heatsink together with a relay that will switch the pad inline/offline with PTT.
    Your amp may already have a pad installed in the transmit path but just the wrong one for your use case and it may be a quick swap to achieve the desired input range.
  • Andrew - G0RVM
    edited January 2020
    I'm not in front of SSDR right now but I didn't think that re-scaled the Power output control just set an upper limit....
  • Andrew - G0RVM
    edited January 2020
    Thanks Dwayne.  Yes, that is the design I was considering. :-)  I currently have an external 10dB attenuator that I was thinking of using if needed.  Cheers.
  • Dwayne_AB6A
    edited January 2020
    The hard part is switching it in and out of the transmit path ;)
  • Andrew - G0RVM
    edited March 2020
    Thought I’d just update this post to describe the hardware solution I now use as it seems to work well.  The scaling of the SSDR Power slider control remains a more elegant solution tho as the additional kit would not be required......A future version Flex?
    I inserted a DX Engineering DXE-RTR-2 and a 50W 10dB attenuator between the Flex 6600 and the SPE amplifier.  The RTR-2 splits the transmit and receive paths so the transmission path is: Flex ANT1 -> attenuator -> RTR-2 -> Amplifier -> Tx/Rx Ant and the receive path is Flex RXB IN <- RTR-2 <- Amplifier <- Tx/Rx Ant.
    A Flex Tx Relay output is connected to the RTR-2 to provide a T/R switch signal.  It should be possible to cascade the Tx Relay signal from the RTR-2 ACC PTT port to the amplifier but this doesn’t seem to work for me. Instead I use another Flex Tx Relay output to switch the amplifier.
    Hope that’s clear and maybe helps someone else.  ;-)
    Andrew
    G0RVM
  • Dwayne_AB6A
    edited March 2020
    Nice ;) Did you poke around inside your amp to validate if there was the possibility of inserting a pad in the internal transmit path?
  • Andrew - G0RVM
    edited March 2020
    Hi Dwayne.  No I didn't.  I took the lazy but expensive approach ;-)
  • Tim - W4TME
    edited March 2020
    Power control scaling is not a feature of SmartSDR.
