CW SPEED & N1MM
W2ECK
Issue is with 6600. When running SSDR alone I am able to control cw speed with slider in CW transmit control panel. If I send with a paddle, I get the speed set on this slider. But when I open N1MM+ and use one of the macros in a contest, I can't control the speed. With the slider down to 10 wpm I am getting 30+ wpm out of N1MM+. I have no other radio related programs open. Any clues as to how to fix this issue?
Paul
w2eck
Paul
w2eck
Solved my own problem, but may be of interest to some else just learning SSDR and using with N1MM+. In N1MM main window, under the RST sent window is a small control to set the speed in N1MM. So that apparently overrides the speed setting in SSDR CW Radio Control Panel.
Paul
w2eck2 -
I use the Page Up and Page Down keys on the PC keyboard to change the keyer speed in 1 wpm increments in N1MM. I use an external Winkeyer with my 6500, due to the lack of being able to tailor Winkeyer parameters (like weight) in SmartSDR on the Maestro.0
You solved mine also. Much appreciated.0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
