I have no RX output at the rear panel headphone jack.
Robby
I have wrestled for several days with this and no luck. I have a FLEX6400 with V3.1.8. I can hear the CW sidetone in my headset but that is all. Other headsets are the same. I am not using DAX. The problem is there in SSB as well. Can anyone help?
see if the volume level for headphone is enabled and the headphone level is turned up
per the manual
also verify you are plugged into headset port and not the powered speaker ...as they are close to each other
Paul K3SF
Yes. It is set properly. I have been using this radio for about 10 months. It is only recently that I have had this problem. I am plugged into the headphone jack. I hear the CW side tone there but no signals from the band. They are normal when I select PC AUDIO.
-Robby
I assume you have restarted SSDR and the radio ?0
many times0
Make sure you have the headphones enabled on the menu!0
What menu?
If I turn PC audio off it works.
That is the way the radio is designed to work. Unless you configure it otherwise in the Settings->Radio Setup->RX tab.0
Thanks Tim,
Figured that out just before the power went out.
OK now. DUH....
power is back on but my brain....??
No worries. 73.0
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
