I have no RX output at the rear panel headphone jack.
Robby
Robby Member ✭✭
I have wrestled for several days with this and no luck. I have a FLEX6400 with V3.1.8. I can hear the CW sidetone in my headset but that is all. Other headsets are the same. I am not using DAX. The problem is there in SSB as well. Can anyone help?
  • K3SF
    K3SF Member ✭✭✭
    edited March 2020
    see if the volume level for headphone is enabled and the headphone level is turned up
    per the manual
    also verify you are plugged into headset port and not the powered speaker ...as they are close to each other
    Paul K3SF
  • Robby
    Robby Member ✭✭
    edited February 2020
    Yes. It is set properly. I have been using this radio for about 10 months. It is only recently that I have had this problem. I am plugged into the headphone jack. I hear the CW side tone there but no signals from the band. They are normal when I select PC AUDIO.
    -Robby
  • Joe N3HEE
    Joe N3HEE Member ✭✭
    I assume you have restarted SSDR and the radio ?
  • Robby
    Robby Member ✭✭
    many times
  • bobby
    bobby Member ✭✭
    Make sure you have the headphones enabled on the menu!
  • Robby
    Robby Member ✭✭
    What menu?
  • Robby
    Robby Member ✭✭
    If I turn PC audio off it works.
  • Tim - W4TME
    That is the way the radio is designed to work.  Unless you configure it otherwise in the Settings->Radio Setup->RX tab.
  • Robby
    Robby Member ✭✭
    Thanks Tim,
    Figured that out just before the power went out.
    OK now. DUH....
    power is back on but my brain....??
  • Tim - W4TME
    No worries.  73.
