Question: Extending physical connections for my Flex 6500
Val  DM1TX
Val DM1TX Member ✭✭
edited February 2020 in FLEX-6000 Signature Series
Hello. As I cannot win the war with my XYL I need to move the working position of my Flex about 4 meters away in the same room. That means that it will be desireable to have on my desk just the CW keyer and Flex mike. That means also that the actual grounding and antenna coax cables will need to be extended with about 4 meters. Now the questions are: 1. Extending the grounding and coax cables will have any impact on receive/transmit? 2. Can the mike cable be extended with a simple CAT6 cable? What would be the pinout to follow? The exttension cables can be close to each other or apart due to RF? I only run 80W here.
As a result I will have a clean desktop (most of the times) and most important a very happy XYL.
Appreciate your help. 73
  • Joe N3HEE
    Joe N3HEE Member ✭✭
    As long as you use proper terminations to extend the coax it should not be a problem.  Extending the ground wire should not be a problem either if care is taken to make a solid connection.
    You can purchase 8 pin microphone extension cables in 5 meter lengths from Giga Parts and other sources.  That would be the easiest and error free way to extend the mic cable.
    I doubt you will have any RFI issues if care is taken with extending the coax cable.  They can probably be located together without issue.
  • Steve Bunting
    Steve Bunting Member ✭✭
    I have three flex radios installed in a cupboard at a Scout centre. These work well in remote mode with all audio passing over the network, but we cannot use microphone and DVK in our contest logger (N1MM) in that set up. I build some long (about 5m) mic and headphone extender leads and they work just fine.
    I am currently on v2 of the system as the first set was built with cheap multi core cable that could not cope with being moved around. The current system uses cable designed for professional musicians who take their equipment to shows and is very durable. There havent been any problems with this so far!
    Good luck with keeping everyone happy
    Steve, M0BPQ
  • Val  DM1TX
    Val DM1TX Member ✭✭
    Thanks everybody for input. Will go ahead with the plan :-) 73
