Sizable cat window
Rich McCabe
Member ✭✭✭
Would be nice if the CAT window could be sizeable by width like it is length. Or better yet just change it to the same width as the DAX panel.
Its fine unless you add enough ports that you pickup a scroll bar and then the scroll bar covers some of the text.
Totally cosmetic but still
Rich
Rich
Hover the mouse near the right edge. A double arrow appears (<->). Click and drag to the right and the window widens. You can do the same thing to the bottom.0
I get the double arrow but will not widen.
The vertical sizing works. But not horizontal width.
