Hamation Bandpasser AS-419
mlstutler
Is anyone using the Hamation Bandpasser AS-419 filter with their Flex Radios? The documentation is a somewhat confusing. I am reading that you have to raise 12vdc to the pin on the remote input to switch bands. I don't see how this can work if the FTDI USB to parallel interface only supply's 3.3vdc.
thanks.
thanks.
I found a level shifter that can be used if the AS-419 requires a 12vdc input.
https://www.tindie.com/products/ddebeer/12-channel-level-shifter-and-buffer/#product-description
Update - We purchased the Bandpasser and realized that BCD can also be used to control the unit. Took about 5 minutes to configure and it works with no issues.3
Hi Mike, can you use BCD right into the bandpasser from the USB cable ?1
Yes that is what we do. Here are screen shots of the config.
Hope this helps.
Please supply the wiring color code to the mouser cam shell FTDI USB unit. I can't get the correct wiring code to make the AS-419 to work.
Thx
Mapping for AS-419 BCD DB-15 port
Grey = A
Purple = B
White = C
Blue = D
Black = Ground0 -
Mike, your the man, Thx..
When you have the letters, I have numbers on my FTDI USB unit cam shell that I **** the colored wires into. Would A=1 , B=2?
Plus its a DB-9 for the AS-419
Thx
David - Did you get answer to the pin mapping? I'm looking for the same thing. Andy NA4DA0
- 354 Community Topics
- 618 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 175 SmartSDR for Maestro and M models
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 25 Aurora
- 218 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 759 Peripherals & Station Integration
- 979 Third-Party Software
