Voltage decreases when transmitting
Santiago Mejia HI8O
Lately when I transmit the voltage reading on my 6300 decreased. Normally it is at 13.5 and when transmit it goes down to 11.5. Any suggestion? 73, Santiago HI8SMX
Need a heftier power supply if the voltage is dropping and the rig is OK.1
Hi Santiago, there are fuses inside the cabinet and they need to be cleaned sometimes. Take them out, clean with de-oxit or similar or rubb them with a cloth.
If you have fuses on the DC cord betwen radio and PS, do the same. Make sure your cabling is as short and as corse as possibel.
I've done this with my 6700 and doing this and thinking about cleaning internal fuses can make wonders for this type of problems.
GL! Johan1 -
Hi Santiago,
Here are some notes you might find helpful.
http://www.nn4zz.com/FLEX6700.htm#Low_Voltage_Lockup
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
6700 Win10 SSDR V2.4.9
.... and before you do this, measure the voltage direct at power supply connectors if you transmit and you will see your psu is to small :-)
The last work what you can do is what Johan says.0 -
There are 3 places to measure the voltage to determine where the problem may be. Power supply issue, cable / connector issue, fuse issue.
Measure:
- at the power supply while both RX and TX (suggest 14 - 15 V here)
- at the power pole connector on the back of the radio ( should be about 0.1 V less than at the supply)
- at the radio side of the fuse with an app like SDRMonitor. expected drops are in my notes.
Regards, Al / NN4ZZ
It is normal that at the radio terminals the voltage overwrites but also the amperage.
In the FlexRadio manual it is recommended to have 13.8v +/- 15%. I always adjust to 14.5 volts at the radio terminal
If it is not a power supply issue try cleaning with Deoxit and "slightly" reforming PowerPole connectors per this thread https://community.flexradio.com/flexradio/topics/undervoltage-powerpole-issue
I had a similar issue and it solved it 100%
73 Dan0 -
I had this problem. I got my total voltage drop, end to end, down to just .2v Made a new power cord from a flexible 10ga wire, applied a small amount of a conductive silver grease to the power pole connectors and to the internal power fuses. Voltage is measured with the stacks program. Running my power supply at 14v0
I took the cover off my 6300 with the intention of cleaning the fuse connections but it appeared I would have to perform major surgery to extract the 30A green fuse. Is there any easy way to get to that thing that I might have missed?
73 de Mike W9OJ0 -
What is "The Stacks Program" and where do we find it?
Neal0 -
Use a voltmeter to determine where the voltage drop occurs. While TX into a dummy load; Measure voltage at Power supply. Measure voltage as supply line as it enter the radio (inside the radio). Measure voltage on the input side of the fuse, next measure voltage on the output side of the fuse.0
It's hard not to get voltage drop with 12 volts DC if you use any significant length of cable. I am a fan of power poles but they contribute as well.
I have a total of about 10' of cable to power the flex which will drop the voltage for sure. So one of my RigRunners is placed under desk at back of radios. I am powering the Flex with a 16" chunk of 10 gauge and the rig runner is powered with TWO 10 gauge runs back to my 50 amp Astron. I am running 13.5 volts at receive and 12.5 at 100 watts TX.
Best thing you can do is cut the cable as short as possible
My voltage is not ideal but when you are dealing with a long run its not easy.
- 250 Community Topics
- 489 The Flea Market
- 7.4K Software
- 332 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 779 Maestro
- 42 FlexControl
- 732 Genius Products
- 254 Tuner Genius XL
- 86 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 119 Contesting
- 585 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 810 Third-Party Software
