periodic slowing of macros in n1mm+ in cqwpxrrty contest
N3RC
On half a dozen or so times during the recent rtty contest, the N1MM+ macros slowed to the point
that I rebooted Win10, SDR 3.1.8 and N1MM+ which solved the problem for 1-4 hours.I tried various combinations
of reboots to no avail. Did not reboot 6600.
I am running v3.1.8 latest N1MM+, 6600, superfast W10 64 computer, usb wireless keyboard.
At first I thought it was a wireless usb keyboard issue but the keyboard worked fine when I used other
apps concurrently with N1MM+.
Ran W1n10 resource monitors could not see anything out of place.
Many things could have caused this. My guesses in order of prbable guilt are:
Win10
N1MM+
SDR v3.1.8
Wonder if anyone else has run across similar issues?
Roger N3RC
Win10
N1MM+
SDR v3.1.8
Roger N3RC
Yes. Only occured to me once and had to reboot the computer and 6600M and re-do N1MM.
I let the computer and radio on all night - not a good idea as I had to reset everything in the morning
Not a good contest weekend as I spent considerable time fixing things. I've ordered a K4 and will do a comparison. However when every thing is working, SO2R on the 6600M is terrific0 -
Did you really have to reboot the computer? That would be surprising to me. Did restarting N1MM+ not fix the issue? Or restarting DAX?
Andy
KU7T0 -
If I overload my computer I see this during RTTY contests. I always keep a Task Manager in the tool tray so I can watch the CPU usage. The computer I use for contesting is pretty beefy but RTTY Skimmer Server running on three bands at once together with somewhere between 2 and 6 RTTY decoders and N1MM+ can really bring it to its knees. Graphics intensive applications like SSDR add to the problem.
I've taken to running RTTY Skimmer Server on a separate computer. I also keep the panadapters that it is using very small with low FPS (10) and Rate (50). I tend to do the same with the panadapter I'm using for tuning.
I played a bit with limiting RTTY Skimmer Server to 4 CPU cores and to run at a low priority. That helped a lot but mostly just confirmed the problem.
--Don
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
