fldigi help
Jim
I know theres a ton of posts regarding this subject and I think ive tried them all to no avail. I believe I have everything configured correctly but I cant seem to decode anything. Is there anyone that can point me at something to look for?
assuming everything is configured - radio should be digiu for pretty much all decodes and make sure the “reverse” button in fldigi is not on. Use the fldigi waterfall and i overlay the red decode on what you want to decide ensuring you are in the right mode in fldigi. if you are in the usa, use netlogger to see advertised digital networks - the saturn network on saturday morning is good as the will flip between olivia and mafk - it took me several tries to get all my settings correct. in rtty contests i will lock down fldigi to essentially be static and run the radio in rtty mode and use the radios waterfall which i find is more effective . comically you have to know what you are decoding. i have struggled in the past with decodes when turned out to be ft8 on an odd frequency.0
Jim,
It might be easier for us to spot something if you post screenshots of all your settings in both
FL Digi and Smart SDR. It's hard to point you where to look when we do not know what you are
seeing.
You say you cannot decode, but can you transmit? Your post is vague.
73, Jim N9VC
If you see signals in the waterfall, make sure that the audio is not from your speaker into your mike input (#1 out of 100)
John, K2CIB0 -
Jim, I am a brand new user of FLDIGI, but I do have it decoding on a Flex 6400. If you want to compare settings on the phone, I would be glad to do so.
Just to add - i would be happy to do a zoom / webex to review settings during an evening this week.1
make that group meeting ! ;-)0
haha! we can do that! A flex radio “twitch” session!0
Thanks for all the replies
I can do screen shots, if you let me know which you need to see. Im also open to phone or TeamViewer if you like.
if you are in front of your set up and want to compare over the phone give me a call at 512 484 5506. keith - wa5vtt the band here only has some week psk signals on 20 but I am decoding some qsos If you can't call before 2 pm central, then it will need to be after 4:30 pm central
Thanks Keith...….. With your assistance everything is working fine!
Thanks, I know we both have a lot more to learn about FLDIGI but getting it initially set up and decoding is step one. We talked about the challenge of identifying which mode to use when you find a signal. I found this instruction on setting up FLDIGI to send and receive and respond to a digital mode identifier that we discussed. https://www.youtube.com/watch?v=nwkz0GNpA0I
at about 3:50 he goes into how to configure FLDIGI for this.also found the following URLs showing what different modes look like in the waterfall and in some cases what they sound like:
https://www.george-smart.co.uk/radio/digital_modes_waterfall/
https://www.sigidwiki.com/wiki/Category:Amateur_Radiohttp://www.hfradio.org.uk/html/digital_modes.html
http://www.w1hkj.com/FldigiHelp-3.21/Modes/
Finally, this article toward the bottom gives calling frequencies by mode and band. Not sure how up to date it is: http://wb8nut.com/digital/
Hello Keith, I'm just about setting Fldigi on my Flex 6600, I have some experience with Fldigi 2 meter VHF transmission for Emcomm using Rigblaster and. Kenwood Radio tuned to a repeater here in San Francisco Bay Area. If you don't mind I would like to talk to you on the phone as I set it up, please let me know a good time my e-mail is armallya@gmail.com.0
Make sure that you have the latest xml file for SmartSDR and that it is in the right place for it to be picked during initiating.
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
- 295 Shack Infrastructure
- 207 Networking
