RTTY SPLIT
Rich McCabe
Member ✭✭✭
So I honestly have never had a need to run split in RTTY until recently with some DXpeditions.
The only RTTY I have ran in recent years is during a few contest and used MMTTY with N1MM which worked fine.
So I just had one contact to make so I fired up N1MM (still set for last RTTY contest) and edited a Macro button for an exchange.
Split on the Flex was easy as usually but my Slice B TX changed back to Slice A when trying to send.
I just reversed the slices and made the contact. Today had opportunity to try it again so fired up FLDIGI and application was once again changing the TX from Slice B to Slice A.
What am I missing here?
Rich
kd0zv
Rich
kd0zv
Open SmartSDR CAT and turn "Autoswitch TX" off on all ports.
Thanks Craig.
Always great to get an answer in 120 seconds
Rich
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
