RFI Finger Print and the Solution
Ken W9IE
Attached is a Screen Dump of the RFI Signature and the Solution.
I have been searching (off and on) for over 2 years for the RFI.
The RFI was much broader than the Picture I am showing here.
It went from 14 Mhz to over 30 Mhz. An interesting part of the
signature is that each Spike had 2 small peaks and they would
switch back and forth at around 120 times per minute as best
I could count.
I finally solved it by putting one of the 28 Mhz frequency's in my
HT and went walking around the neighborhood.
My neighbor was very helpful by switching off breakers. It was
kinda elusive though.... It was under a bunch of stuff in the garage
and left plugged in. The RFI was active regardless of it having a
battery in it or not.
I do not want to imply that all Hitachi battery chargers are bad.
This is just one that went dirty.
My Neighbor now has a Brand New Top of the Line Cordless Drill
and charger.... My Gift..
73's and I hope this might help someone find a similar problem
Ken W9IE
I could count.
Ken W9IE
That's awesome Ken! Good job!0
Found the exact same issue with Ryobi Charger for their battery packs.0
The fingerprint solutions can also get by some of the technique by which you can get that exact solution which you want can also get from the Hp Tech Support for more information and knowledge then try to contact with them.0
UIDAI desires to enhance its device technology and specifications in collaboration with the Industry partners with a special emphasis on the integrated Brother Wireless Printer Setup devices to facilitate the large-scale adoption of authentication for consumer transactions.
noushad the "Troll" Fair warning, don't click on the link.0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
