VFO line does not match RTTY waterfall signals?
Neal Pollack AB6G
Today I noticed that if I switch to RTTY mode, the VFO tuning "line" does not match RTTY signals on the waterfall. If I switch to CW, and put the VFO tuning line over a CW signal on the waterfall, I hear it in the speaker, no problem. It lines up. But when I switch to RTTY, if I put the VFO tuning line on a RTTY signal on the waterfall, I hear nothing. If it tune left or right, I hear RTTY signals, but not where they are visible on the waterfall. It's almost like there is an offset.
I did set RTTY tones to 1275 and 170 shift.
Any ideas what I am overlooking? It is currently like I am flying blind. I have to ignore the waterfall and simple tune and listen to find RTTY signals.
Thanks for any ideas.
Neal
Neal
Neal, why you like to using Low Tones ?
99,9% of all RTTY op's using High Tones
73 Chris0 -
If you had to wear hearing aids, that like to generate feedback at 2125,
you might then undertand why I like to use low tones. The hobby should not
cause pain :-)
Cheers,
Neal0 -
Back on topic; While in RTTY mode, the tuning line for the VFO is not matching RTTY signals on the waterfall. It is almost like there is some sort of offset going on. Does anyone have any ideas about what to check?
Sincere Thanks,
Neal0 -
Neal, maybe it's helpful to show us a screen shot of the right side of the SSDR screen..
I personally do not have seen that problem on my 2 F6 in the past - and i working RTTY
Chris0 -
The RTTY mode works fine, one has to make changes to the setups if using unconventional tones.
At this station, Mark frequency is 1kc. In SSDR one sets the Mark as 1000 on the DSP take. The RTTY modem needs setup also. By way of example, FLDIGI has the sweetspot set at 1085. This is (Mark + Space) / 2. Also the RTTY modem Transceiver FSK is set to 1Kc.
On the fldigi waterfall, with narrowest RTTY filter selected, the audio channel is dead center. When a signal is received, the AFC in fldigi tracks and locks. Hitting the QSY button brings one right on frequency. All panfalls - waterfalls and frequency readings agree and are accurate.
Beats the days of LC- filters, drifting transceivers, o'scopes for tuning smell of oil and grease from the TTY. (but those were fun days too!).
_..--
k3Tim
RESOLVED: It was the hint that Chris gave in the first answer above. There are apparently THREE places that the MARK frequency needs to be set to match each other (IF you are chaning to lower or different tones):
1. The RADIO menu default, per Chris' screenshot above.
2. The Slice Receiver Menu.
3. The "PHONE/CW" sub-menu on a Maestro
And lastly, make sure you set it to match in your software program on the PC, like MMTTY or FLdigi.
I use a low MARK tone of 1275, which is much more friendly for my hearing aids (The default MARK of 2125 causes feedback, not fun). But of course, you can use anything you wish, as long as all the items above match (are set to the same MARK frequency).
Thanks Chris and Tim.
Neal
- 109 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
