FLEX-6600M and RTTY Skimmer Server
Conny
How to use a RTTY Skimmer Server with FLEX-6600M, presumably via the SDR-Bridge?
Using Windows 10 Pro and the latest available Skimmer and bridge version.
Not been able to get any reliable connections or streaming.
Anyone have success with this configuration
Got this from W2RF:
Sometimes it is necessary to remove other unused drivers from the SkimServ directory. The most frequent problem is Qs1rIntf.dll, which is installed with Skimmer. I usually just rename it to .dllx.
I renamed the mentioned DLL in both SkimServ and RttySkimServ. Skimmers now starts up reliable each time, but current versions have some issues with sharing the same IQ stream. So for now, the last started Skimmer takes the stream from the first started.
I did let W2RF know about this IQ stream issue.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
