Radio not available
Brent N9BC
I have a strange problem that just happened today. I just started working the MN QSO party today and noticed after about 2-3 contacts they was a delay in switching from TX to RX 2sec or so. I did shutdown of my 6500 and turned it back on. I go to connect via SmartSDR and no radio to be found. So I did a cold reboot and factory reset. When I tried again. I showed my flex was available. When I tried to connect I was unable to connect. I thought that was odd maybe my switch was acting up. So I swapped out my switch and tried using my Maestro. Same thing it would should up but would fail but on the Maestro it loaded partly the it would connect then disconnect after about a 1 sec. I left it unplugged for a bit and did a few more reboots cold boots and factory resets. Any ideas what is going on? Or any ideas what I should try? Thanks - N9BC
Router and all switches have been rebooted.0
Did you disconnect the power ... not just turn the rig off but disconnect it totalky0
Yes disconnected the power and let it sit for a few minutes.0
I would try signing in again. When I remote my station, I get the same **** sometimes.
I just sign in and all is good then. This is just a suggestion. It can'r hurt. Works for me,
Good luck. please post your findings.0 -
Same result. It’s like the server is crashing on the 6500. I’m able to ping the 6500 just not able to connect to it.0
I remember I had to go through a key up , It asked me to key the radio within a certain amount of time, I herd a ding and then all was good? did you ever have to do that at any point? I don't own a 6500, mine is a 6300.. But did you ever have a pop up that had a timer counting down asking you to key your radio from the station itself?? Just trial and err here.
Good luck, let us know.0 -
Unfortunately no count down timer. I'm going to do a PCAP tonight when I get home from work. And see if the 6500 is replying to the packets maybe that will show me something. But I do think its time to engage flex support. Thanks for trying .
Brent
Quick update. I did a wireshark packet capture and was able to determine that my PC was in fact talking to the 6500 at some level. During the connection setup the 6500 would stop communicating to SmartSDR. Working with Dan in support he suggested we downgrade to 2.6.1 so we downgraded. Rebooted the 6500 and sure enough SmartSDR was able to connect back up. When proceeded to upgrade back to 3.1.8. After the upgrade was complete we tried to connect back up and wha la We are back in business. I can't say enough good things about the support. Thanks again Dan N7HQ!
Brent N9BC
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
