Any one know if the 1/8 jack mic input on the 6400 is hi or low impedance I’m hooking a w2ihy box
Joseph Coffaro
Page 13 of the 6400/6600 Hardware Manual indicates 600 ohms nominal then indicates 200 to 10K ohms range. I have used both a 600 ohm mics as well as an old HI=Z Astatic dynamic mic with no problems.
------------------------------Here is a snip from the manual.-----------------------------
Microphone Impedance 600 Ohms Nominal, 200-10k Ohm
The Manual is downloadable from the Flex web site.
GayLe K0FLY
Thank u sir hopefully my re320 will sound good looks like every one is using pr781s0
https://www.flexradio.com/downloads/flex-6400-and-flex-6600-hardware-reference-manual-pdf/
per the h/w manual fro 64007.20 MICROPHONE JACK
The MIC connector accepts a 1/8-inch (3.5mm) stereo (TRS) plug and provides a pseudo-balanced microphone input. Pseudo-balanced means that the mic (+) and mic (-) lines are balanced all the way to the input of the A/D converter, where the mic (-) line is DC grounded. The connector may be used with dynamic or electret microphone elements. A software enabled 3V bias voltage through a 2.1k Ohm source impedance may be applied to the Mic (+) line for electret microphones.
Note: The PTT signal is not accepted by this connector.
Paul K3SF
I use an RE320 with my Flex 6500. It is great mic for voice. I am always getting compliments on my audio.
Thanks u sir0
Do u use a microphone preamp0
No, the mic runs directly into the radio. The mic input has plenty of sensitivity for almost any dynamic mic.
I use the MXL CR77. Looks exactly like the Heil PR77. Very nice dynamic mic.1
Your RE320 will work very well. Just make sure to cut the low frequencies with the TX equalizer.1
i know ur voice is different then my u share ur settings with me?0
The transmit voice can be recorded on the Flex and then played back. When adjusting the TX equalizer, cut unwanted frequencies (mostly low frequencies) before trying to boost. What is not there can't be created with boost. After much trial and error, I ended with just a flat EQ curve and adjusting the TX bandwidth to cut below 250 Hz and top end cut above 3000hz or so. Excessive low transmit audio frequencies consume transmit power without adding much intelligibility.
- 323 Community Topics
- 588 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 392 SmartSDR for Mac
- 257 SmartSDR for iOS
- 246 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 12 Aurora
- 147 FLEX-8000 Signature Series
- 904 Maestro
- 50 FlexControl
- 862 Genius Products
- 304 Tuner Genius XL
- 114 Antenna Genius
- 272 Shack Infrastructure
- 192 Networking
- 436 Remote Operation (SmartLink)
- 135 Contesting
- 711 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 935 Third-Party Software
