Profile PTT Outputs Using SSDR 2.4.9, 6400, and Transverter
Geoff AB6BT
Member ✭✭✭
I have a question regarding PTT outputs on my 6400 and profiles. I just installed a 2 meter transverter. I assigned TX3 as the PTT line to enable transmit on the transverter. So far so good and it works as expected.
I noticed that the default seems to be that ACC TX, TX1, TX2, and TX3 are enabled in Global (EDIT: actually Transmit I believe) profiles by default.
For keying my HF amplifier I am using ACC TX only.
Does that mean that I have to disable TX3, in all my profiles other than the ones that use the transverter?
Thanks for any assistance.
Yes, set only the needed TX rca jack active in the TX profile you use for your transverter. Like wise for your TX profile you use for HF and amplifier.0
Thanks Larry. I had never looked at the default settings of the PTT outputs and as I was only using the ACC TX it had no impact. Now that I've added more hardware the issue surfaced.
Now to edit all the transmit profiles...0
- 379 Community Topics
- 636 The Flea Market
- 141 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
