Output power control
Andrew - G0RVM
The Power output slider on SSDR (2.6.1) is great and gives granular control over a 100W range (Flex-6600). At a setting of 1 my SPE amplifier generates about 120W; at 2 it generates about 380W. I would like to have increased granularity of control when using CW so a higher setting - perhaps 5 or 10 - results in 380W or thereabouts. Put another way, I'd like to configure the upper limit of the SSDR Power output slider to a value - perhaps 50W - and distribute that across the entire range of the slider control. Hope that makes sence.
I don’t think the upper limit of the SSDR Power control is configurable so the only way I can think to achieve greater control is to add an attenuator in the transmission line between the Flex and the amplifier. The problem with this approach is that with a single antenna the transmit/recieve path is shared. Thus the attenuator needs to be removed from the receive path, preferably automatically via transmit/receive switching.
Just wondering if I'm missing something? Perhaps SSDR can be configured differently?
Andrew
G0RVM
Andrew
G0RVM
Scaling the power output control to better tailor driving a linear amplifier is a great idea. Maybe it can be implemented in future updates.'
Perhaps something like this:
0-25
0-50
0-75
0-100
Jim, K6QE2 -
"I don’t think the upper limit of the SSDR Power control is configurable "
Settings >> Radio Setup >> TX tab >> Max power Change 100 to your desired max output power.
When I ordered my amp to match my 6600, I was able to specify the input range and chose 50W -> 1000W vs 5W -> 1000W and other options. Learning more about my amp, I found it is using the A1000-100-11X 10dB pad https://www.barryind.com/pdf/Attenuator/Power_Flange/A1000-100-11X.pdf to control input attenuation. Worst case (and a nice Sunday project) is a small circuit that incorporates a pad mounted to a heatsink together with a relay that will switch the pad inline/offline with PTT.
Your amp may already have a pad installed in the transmit path but just the wrong one for your use case and it may be a quick swap to achieve the desired input range.0 -
I'm not in front of SSDR right now but I didn't think that re-scaled the Power output control just set an upper limit....
Thanks Dwayne. Yes, that is the design I was considering. :-) I currently have an external 10dB attenuator that I was thinking of using if needed. Cheers.
The hard part is switching it in and out of the transmit path
Thought I’d just update this post to describe the hardware solution I now use as it seems to work well. The scaling of the SSDR Power slider control remains a more elegant solution tho as the additional kit would not be required......A future version Flex?
I inserted a DX Engineering DXE-RTR-2 and a 50W 10dB attenuator between the Flex 6600 and the SPE amplifier. The RTR-2 splits the transmit and receive paths so the transmission path is: Flex ANT1 -> attenuator -> RTR-2 -> Amplifier -> Tx/Rx Ant and the receive path is Flex RXB IN <- RTR-2 <- Amplifier <- Tx/Rx Ant.
A Flex Tx Relay output is connected to the RTR-2 to provide a T/R switch signal. It should be possible to cascade the Tx Relay signal from the RTR-2 ACC PTT port to the amplifier but this doesn’t seem to work for me. Instead I use another Flex Tx Relay output to switch the amplifier.
Hope that’s clear and maybe helps someone else. ;-)
Andrew
G0RVM1 -
Nice
Did you poke around inside your amp to validate if there was the possibility of inserting a pad in the internal transmit path? 0 -
Hi Dwayne. No I didn't. I took the lazy but expensive approach ;-)
Power control scaling is not a feature of SmartSDR.0
- 655 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 968 Maestro
- 940 Genius Products
