Loosing tx power 6400
Mark Chamberlain
Mark Chamberlain Member ✭✭
HI, I have over the last 6 to 8 weeks had no transmit power after powering up my 6400 5 or 6 times.
Everything on screen shows as per normal when TXing i.e. I get a red TX at the bottom agc and compression meters come to life however NO power or SWR indicated or delivered.
TX can be restored by powering down and removing the power cable from the back of the radio for 30 seconds then power back up and away. Today I made contact with a station and could not reply as I had again lost TX this was the 1st time I had lost TX after getting the 6400 working
Flex 6400 no internal ATU using an LDG at 600 pro 2. connected to the PC via a network switch bottom display shows full connectivity all bars green. Running version 2.6.1 PC running windows 10 also up to date.
Any suggestions greatly appreciated.
Mark
M0ZSS
