Smart SDR 3.1.8 not remembering RX antenna setting on 40m
N1DZ
On 40m I use antenna 1 for RX and TX. When I switch to another band that uses antenna 2 for RX and TX and I go back to 40m the RX antenna for 40m is not antenna 1 anymore but antenna 2. The TX antenna is the correct antenna 1. Every other band remembers its antenna settings correctly. Only on 40 m does the RX not remembers its setting.
Using a 6600 and Smartsdr 3.1.8 on Win 10 computer.
Looking forward to a solution.
Thanks.
Thanks.
Read the SSDR manual section that refers to "Profiles". Once you set them up, you'll never have this 'problem' again!1
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
