WSJT--X and CW Skimmer Stopped Working
Greg
CW Skimmer and WSJT-X stopped working. No signals on the WSJT-X waterfall spectrum display. I show a good input level on the level indicator. If I open an old wave file from before the problem started I get a good decode, using a current wave file no decode. I listened to the wave file and there is no audio only some low level hum. For CW Skimmer I see distorted signals, noise, on the display. DM-780 does decode CW and PSK-31 correctly.
Flex 6400
WSTJ-X ver 2.1.2
CW Skimmer ver 2.1
Slice Master ver 0.10.7b
SmartSDR ver 3.1.8
This problem started after I reverted to the default profile from a saved one I had created. Not sure if the profile had anything to do with the issue.
Flex 6400
WSTJ-X ver 2.1.2
CW Skimmer ver 2.1
SmartSDR ver 3.1.8
Look Inthe DAX panel and see if it is streaming while using WSJT or CWSkimmer... no DAX, no decode even with Slicemaster0
Slice A shows good level in the DAX panel. Tried to use DAX RX 2 which is what DM-780 was using and still no signal in WSJT-X. Seems to point to Slice Master not correctly connecting the signal to WSJT-X?
Look in SliceMaster to see if the slice has launched using the launch tab... by mode. And that SSDR is in the proper mode... DIGU0
Slice Master is loading WSJT-X by Mode, set to DIGIU using slice A.
Check the Sync tab and the TCP CAT listener setting0
Bruce,
The the TCP CAT listener on the sync tab is an alternative to using the TCP port option on SSDR CAT. It is intended for use by programs NOT launched by Slice Master. When Slice Master launches a program it will internally allocate a rig control port just for the program being launched.
--Don
Greg,
Have you tried rebooting the radio and/or restarting the DAX control panel? I find that if I run the radio or DAX too long without a restart the DAX audio gets corrupted and decodes fail to happen. While I really do hate to suggest it, rebooting the computer too wont hurt either.
--Don
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
- 456 Remote Operation (SmartLink)
