PGXL Touchscreen problem solved
James Eastham Jr
There does not seem to be any touchscreen capability on my amp. Anyone else have this issue?
Hi James,
This will reset the amplifier and require that you use the PGXL Windows utility application to re-configure it. Also note, there is a very recently discovered firmware bug where the x-y calibration data for the touchscreen will not be saved in non-volatile RAM unless you click save using the utility.
Dan1
- 389 Community Topics
- 53 Aurora
- 970 Maestro
- 944 Genius Products
- 307 Shack Infrastructure
