6600 flashing red 3.18 software
Bert Sharp
6600 attempt boot up green flash as original the shuts back to slightly more rapid red. Know they had fan problems and software was supposed to fix this....any ideas??
now it came on but it took 4 tries turning it off and waiting several minutes0
If it is a fault, you can count the flashes and tell what it is detecting. Keep an eye on it, if it continues to do this start a support tick right away
Also when you turned the radio off did you pull the power cord out as well, otherwise the re boots may not have the needed effect untill you try a few times as you did.
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
