Any using a ETH008 for remote switching successful?
Chris DL5NAM
Member ✭✭✭
Looking for any user of the ETH008 remote switching board. Locally it work's here very well to switch radio and other devices here in shack but if i using over the internet with port address the ETH008 does a reset.
73 Chris
73 Chris
Mine works perfectly both locally on my LAN and over the internet. Not sure why your board does a reset... 73 Hans Christian LA9AKA0
Do you use given port 17494 or did you change it?
Chris, I used the standard 17494 port. Does it reset every time you try to change a relay state? Or reset randomly? I had a MicroBit webswitch1216h earlier, when I used the standard port 80, something was attacking the unit from the outside and causing the webswitch to reset all the time. When changing to a different port, everything was ok again. 73 Hans Christian LA9AKA0
That's what i wrote today to the UK factory of ETH:
if i connect ETH008 here locally with Chrome Browser and his IP address without port extension = works well, menu came up
if i connect ETH008 here locally with Chrome Browser and his IP address and port extension 17494 = ETH008 do a Reset and switch always 3th channel ON; all others used b4 are OFF ( 3th channel was at this time not in use)
if i connect ETH008 over internet with Chrome Browser and his IP address and port extension 17494 = ETH008 do a Reset and switch always 3th channel ON; all others used b4 are OFF ( 3th channel was at this time not in use)
Have seen that after ETH008 has done reset he switch last used channels for a part of a second ON and then OFF (flash)
Chris0 -
Sounds weird, I have no idea why this is happening. I know there are other users of this board in here, maybe they will chime in. If you are an iPhone user, have you tried to use the iOS app? 73 Hans Christian LA9AKA0
Hans, via Android APP locally also no problem. With smart phone via internet = Reset (allways when i use port number)
Will try IPad - if same behavior = another piece for the junk box :-)
Then i will switch to any other brand (not RemoteRig)
73 Chris0 -
Hi Chris,
I’m using the ETH002 without any issues local and external. If you need some screenshots from my fritzbox or other settings please mail me (call at Darc.de). This little server is quit genius for remote :-)
73 Chris DM5HF
Maybe a screenshot can help, i using a FB7490 and have opened port 17494
You can send me direct: dl5nam@t-online.de
73 Chris
You got an email - 73 Chris0
- 112 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
