Problem losing in using Smartlink on SSDR for iOS
W2ECK
Trying to log in remotely using SSDR for iOS on an iPad. When I tap on the You are not connected” opening page in SSDR for iOS, I get the screen shown in attached pic. I click on my 6600 Smartlink choice. It then immediately goes back to the You are not Connected screen. Anyone had similar problems or have a suggestion on how to fix.
Paul w2eck
Paul w2eck
This happens to me every so often on my iPhone. The only why I have been able to fix it is to power cycle the phone. Power cycle the iPad and see if that works.1
There is never a need to power cycle. There is probably something wrong with the SmartLink setup or the network. There are several suggestions how to track this problem down at the end of the Manual (chapter common issues).
I would suggest to start by tapping the (I) Icon on the connection screen which provides more information about the SmartLink connection. Scroll down until you see the remote UDP and TCP Ports. If they show values like -1 or if these values don’t match the ports you have entered when setting up SmartLink, your SmartLink Setup is not working correct.
Marcus
see attached. The UDP and TCP ports match exactly what was entered when setting up Smartlink. In addition I can connect using Smartlink on a notebook computer, so I maybe not a Smartlink issue.
paul
w2eck
I get this result sometimes. I've learned to wait it out & it connects ten or fifteen seconds later. I'm guessing that a delay somewhere caused this & I was to anxions at first & started over. Repeat, repeat, repeat.....0
I am starting to think problem is either wifi network where I am staying or some issue at home. Originally I was able able to connect to my 6600 from here using SSDR on Win10 notebook., but not on iPad & SSDR iOS. But now can't connect on Notebook either. Using notebook Smartlink shows the 6600 is available, but I keeping getting unable to connect msg. Going to try from a different location while on trip.
73 Paul w2eck
The other item that used to cause me trouble is the Maximum Transmission Unit (MTU). Since then the MTU has been made adjustable in both SmartSDR for Windows & IOS. The default is 1500 which is too large for many Internet connections. A better number seems to be around 1200.1
Bob Marcus suggested i try that. But just tryiny to connect with it off. It had no effect. Paul0
So tried to logging in to home QTH 6600 via smartlink using wifi at two different locations on trip home, first using a win10 notebook and then an iPad. With the notebook when I open SSDR all 3 windows (SmartSDR SmartSDRDAX and SmartSDRCAT) open showing the radio is available- see pic below. But when I try to connect after a wait, I get the "Unable to Connect to Radio - please try again" msg. When I try using the iPad and SSDR for iOS, it shows the radio available via Smartlink, but when I click on it, it returns to the you are not connected screen. So right now I am stumped. Have not been able to consistently use my 6600 remotely since I got it. Thinking at this point need to submit a ticket to Flex.
73 Paul w2eck
73 Paul weck
Paul, I don't expect DAX or CAT to be related to your problem but they are not needed on your remote laptop for SSB or CW. I don't even install either one unless I need DAX to connect audio to digital software for PSK31, Etc.0
- 375 Community Topics
- 103 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
