Acom 600s not working with DDutil v3
Santiago Mejia HI8O
Good morning and HNY for everyone! After reading all community posts I've found on this matter I just can't seem to make my Acom 600s and DDutil talk to each other for the life of me. I've tried all processes in previous posts and nothing is working.
Acom is following the Flex nicely and it even works with Acom Director, but I would like to have it working with DDUTIL (to use less software concurrently).
My setup is:
- Flex 6300
- SmartSDR v. 3.1.8
- DDUtil v3
- Acom 600s
- I have the USB cable going from Acom to Flex (including the RCA for PTT)
Any advice would be welcome.
Santiago, HI8SMX
My setup is:
- Flex 6300
- SmartSDR v. 3.1.8
- DDUtil v3
- Acom 600s
Santiago, HI8SMX
HNY Santiago!! Since you are running SSDR 317 you need DDUTIL V4.
Thanka John. Looking for download V4 but can't find it. Got link?0
Found it. Nevermind. Let's see if it works.0
Nope. Not even with V4 can I get it to work. I'm sure its a rookie mistake on my end, missing something logical.0
Ok, we have the 1st issue fixed. Check in SSDR under settings > TX settings, to be sure you have the TX line enabled. Otherwise my support ends here as I do not have an Acom 600s to try to duplicate the issue. If you are still having problems though, you may wish to consider making a post on the DDUTIL reflector/forum.
Yes, I did posted there a couple of weeks back but got no answer. Will retry.
Thanks.0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
