Do panadaptor spots work with N1MM and SSDR 3.1.8?
edited January 2020 in SmartSDR for Windows
Can't get spots to display using N1MM+ and SSDR 3.1.8. Does anyone else have this working?  Any tips?  73 John N5cq
Welcome!
  • Company Adviser ✭✭
    edited January 2020
  • Member ✭✭
    edited January 2020
    I have previously read that link, and am setup as it describes, but cannot see spots. I have two specific questions:
    (1) That document refers to SSDR 2.x. Is there is any difference with 3.x ?
    (2)  Will the spots work remote?
    73 John N5CQ
  • Member ✭✭
    edited January 2020
    John,
    If you have the UDP port enabled in SDRCat and have the settings in N1MM as described in the pdf it should work. I just tried on my Maestro running SSDR  2.60. Once I had N1MM set properly I had to restart N1MM for the spots to show up!
  • Member ✭✭
    edited January 2020
    I think possibly, you meant to state, If you have the TCP port enabled in SDRCat.
    Which seems, to work for me.
    Jay - NO5J
  • Member ✭✭
    edited January 2020
    I too have 3.18 and N1mm configured as per the instruction and no spots.....with an earlier version of SDR spots worked easily.
    Is 3.18 compatible with N1MM ????
  • Member ✭✭✭
    edited January 2020
    It works for me. Am away from the shack at the moment, so can’t give you too many details. But, it definitely works.
  • Member ✭✭
    edited January 2020
    I cant get cat port to say "Process: n1mm"  says none.
    tried many combinations.   I have n1mmspot as a process when click on protocol but cant get it as process on cat port    flex 3.1.8 latest n1mm   just wanting spots, worked fine on earlier version of sdr.
  • Member
    edited January 2020
    I used the PDF mentioned and have spots from N1MM+ showing up in SSDR v3.1.8
    While this is working I don't see a "Process:" status next to the N Port for UDP 12061 that I created in SSDR CAT
  • Member ✭✭
    edited January 2020
    Thanks.... the examples show n1mm as a process on the cat port... I been chasing something that's apparently not required.
  • Member ✭✭
    edited January 2020
    oh a question... on the cat port theres a box with a c,o,w or other big letter in it, what letter does your working port show?
  • Member ✭✭
    edited January 2020
    sorry overlooked the N port.   u using the 127.0.0.1 address on spots? ive tried other including Ip of computer with no luck.
  • Member ✭✭
    edited January 2020
    I think we have established it will work with 3.1.8 on a local LAN connection. Is anyone successfully seeing spots operating remote via SmartLink? Did you have to port forward from the 'transmitter site" instead of using the "local" address of 127.0.0.1:12061 ? If so, how is it set up?
  • Member
    edited January 2020
    Finally got spots and N1mm to work.... I had to go to window and telnet and try to connect to a cluster, many failed but finally one worked and I have spots.
    I wonder why none else had to do this, all documents show a simple 2-3 step process, none worked for me without using telnet cluster connect.
