Using Faros with SmartSDR
Initially, I had trouble installing and running Faros. On Windows 10, I got it working in XP compatibility mode. If you get error messages when first running the program, it may be because there is no sound input. The "Settings" menu for sound input selection is under the "View" menu. On SmartSDR, set the CW bandwidth to 3.0 K.
I set Faros up to control the 6300 using the Flex CAT program via OmniRig. I initially chose DAX for the sound data input. However, there were problems with the timing of the sound data and Alex (VE3NA), the author, suggested to use a direct sound output from the 6300 to the PC's sound input jack. This worked much better.
Faros now runs smoothly with SmartSDR checking the 18 radio beacons and plotting the data. Very nice!
Please contact me if you have questions.
Richard
AE5XO
Correction: Faros seems to install on most Windows 10 machines without using compatibility mode.
Richard
where do you get the software?1
Richard
Saw your post on Faros from a few years back. Trying to get Faros to run with my 6600. The CAT control of the radio is working fine, shfiting the bands and freqs on time. I hear the beacons but they are not being recorded in the Monitor, History or Details tab in Faros. I have sound input from the 6600 going directly to the PC soundcard. Any ideas on what I may have wrong, or could you share a screenshot of your OmniRig setup?
73 Paul w2eck
Paul
It has been a while since I did this. I'll see if I can remember!
Richard
Richard - thanks appreciate it
73 Paul
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
