SmartLink - Can I control Maestro with N1MM+ in version 2.6.1
Steven WA8Y
Want to control N1MM+ locally next to Maestro for a CW contest. Not sure it is possible with V2.6.1
I do it remote but I get no sidetone and delay makes timing TX/RX difficult if 200-300ms latency connection.
Yes, it works fine for me with my Maestro using WinKeyer emulation.0
I open N1MM+ on my laptop. Started SmartSDR v2.6.1, DAX and CAT.
Made same CAT Com7 (Serial Slice A N1MM+Logger),
Comm8 (N1MM+Logger Serial Slice A process N1MM+Logger
and Winkeyer Com9 (N1MM+Logger) as I have at Home.
Then in N1MM+, I configured the same three ports, (copied what I have at home).
When I leave the Config tab and go back to Config tab (in N1MM) all my setups are erased.
What am I doing wrong?
I am trying to use it with SmartLink
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
