Maestro Internal Battery - Any other steps?
I have a Maestro Model A that has bricked (no boot) after being unused for a couple of months.
I have followed the procedure given in https://helpdesk.flexradio.com/hc/en-us/articles/360004514391-Manually-Re-charging-the-Maestro-A-Internal-Battery to charge the internal battery for several hours but still no joy.
Are there any other steps I can take before I arrange for a trip back to Austin?
Bob, K8RC
Bob, K8RC
In your Maestro it’s Dell tab juste disconnect your Dell tab and plug charger to your Dell tab. Maybe change battery in your tab.0
Try following this procedure:
http://www.flexradio.com/downloads/maestro-a-internal-battery-charging-procedure-pdf/
Regards
Ronald/W4RJF
Did any of you notice that I said I had already DONE the internal charging procedure?0
@ Bob K8RC
One of my Maestros required being left on charge a couple days to recover from a non-charging battery issue. Easy extra step to try if you haven't tried it.
Make sure you have tried a USB "Slow" charger during your rescue operation, as apparently the high amperage style main tablet charger leaves the protection circuitry in a state where it doesn't take the charge. Must be a case of took much of a good thing?
If the battery truly is kaput, some folks have replaced it on their own, or had a service like Batteries+ replace it for them. FRS also does a replacement service.
A past EOL battery isn't likely to come back, and some say it a high risk for swelling.
GL and 73
Steve
K9ZW
Blog: http://k9zw.wordpress.com
Here is the battery you will need to replace the internal Tablet battery.
as others have stated charge the battery for a couple of days before you put it back together to make sure the original battery is toast.
Also you want to change the new Battery a couple of day before you put it in.
Best if you use a external charger like a 2A cell phone or tablet charger to charge the internal battery.
https://www.amazon.com/dp/B06XSX6MLW/ref=dp_cerb_1
I found a couple short cable that I made a Micro USB cables mail and female so I could charge the Tablet independently of the charging circuit in the Maestro that just plug together in the external battery compartment so I can even charge it now from my external battery with out pulling the case apart just in case.
I think these cables came in some external batteries I purchased and like a good ham I never through anything like this away but the cables may be available from EBAY or Amazon, I think they where about 12" long and fit perfectly.
If I find some I'll post here
Bret
WX7Y
I think this is like one of the cables I used https://www.amazon.com/CableCreation-Braided-Adapter-Function-Aluminum/dp/B01M1K8B1W/ref=sr_1_15?keywords=short+right+angle+Micro+USB+cable+to+female+USB&qid=1576802814&s=electronics&sr=1-15
and this one https://www.amazon.com/StarTech-com-Micro-USB-Cable-Angle/dp/B003YKX6W2/ref=sr_1_9?keywords=short+ri...
Remove the MicroUSB to MicroUSB original cable between the Flex board and replace it with these two cables then route them up into the external Battery case when the case is back together plug the two USB cables together and the Maestro charging circuit will be back to normal.
This way when you want to charge the battery separate from the Maestro you can use the External battery or a external USB 2A charger with a USB male to female extension cable and a 2A 5V wall wort.
Your mileage will vary and do this at YOUR own risk
Bret
WX7Y0
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 193 DAX
- 39 Aurora
- 948 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
