PC Speaker or Flex Speakers
Santiago Mejia HI8O
I know this topic have been discussed earlier but my question is rather simple, I guess. What is more recommended: using separate speaker for the Flex (in addition to PC speakers) or using the PC speaker thru PC audio?
I can go either way.
santiago
santiago
Whenever possible I use Flex speaker out. There is a very slight latency when using Audio from the PC which is a stack up of Audio to Digital to PC Audio from the PC.
Just my preference. I do operate on my laptop, over WiFi using laptop speakers and it works fine.2 -
Thanks Mark. That’s what I’m doing now, just wondering if someone have found an advantage either way.
Santiago0 -
The PC audio is feeding thru my HDMI cable , I do lose a little latency or something like that ,. Audio PWR out or phone jack out Is the question I have . What is the best audio ? What is the details , 48000 hz. Etc PCM ? The WNB filter is amazing,0
Agree, speaker out from the Flex is best.
Whatever sounds best to your ears.3
I use a pair of COMSpkr from west mountain, great price, great sound, just plugs into Flex 6300 here. I usually operate remote, and I like having an on/off power switch so the radio is silent with no opportunity to make noise when operating remotely. Link: https://www.hamradio.com/detail.cfm?pid=H0-0091492
I use the Heil parametric audio system with the powered speaker. Very low distortion and very configurable audio. Much faster than using the slide audio in the flex. Knobs work well here. Also the Heil audio system is well protected against rf interference even with a leagle limit amp.1
If you really want to hear just how good the flex audio is, get some Bose companion speakers or other good quality speakers.3
I am interested but what is the Heil audio system. Could you elaborate please?0
My Flex now comes through my hearing aids and that is GREAT. But before that I ended up buying a GOOD set of computer speakers. I found a set on Amazon (Wood case) that have very good sound. I started using it through the computer but then I would find myself wanting to use the computers sound for something else. The separate speakers sound very good and I am free to use the computers audio for YouTube of something like that at the same time.
I will say when I used the computer speakers I never had any problems with it unless I was on a weak WiFi and that was to be expected with the Flex. So either way works just depends on what you want to do while you are listening to the Flex.0 -
I use the 6700's speaker output to drive a set of Bose Companion 2 speakers.
I found the audio from the radio does not directly drive the monitor speakers that well, and my PC sound card also has overall volume limitations as well.
YMMV.
Mike K9MK
When I started with Flex I had a couple Palstar SP30H speakers that I had used with my Icom 7800. I bought a cheap amp off EBay to power them from the Flex. They worked fantastic.
When I upgraded to a flex 6600m I needed to get rid of them as they were large and did not have space for them directly in front of me so I bought bose companion 2 speakers which have 2 inputs so you can run PC and the Flex and mix the audio.
For the most part the audio is good for SSB but not as good as the Palstar/amp setup. For SSB its good but for critical CW listening they do not cut it for me and I have to put on headphones.
I am considering going back to smaller Palstars but have not made up my mind yet.
Klipsch ProMedia 2.1 in my shack, wired to both the computer and the Flex. An A-B switch lets me flip between the two.0
How do you get Flex audio to your hearing aids?
Michael -- KM6LHD1 -
Is the plug on the back of the 6400 mono or stereo?0
Stereo. You can have one slice on left speaker and one on right
thnks0
For CW operators, another reason to use speakers attached to the radio might be this:
(From Al, K0VM and others in other older threads:) The sidetone (CW ?) is generated by the radio but it is not passed to the PC over the ethernet connection. Thus if you have speaker/phones attached to the radio you will hear side tone but if your using the Remote audio feature in SSDR to listen through the PC sound system, you will not have sidetone.
Some of us have been operating our Flexes for embarassingly long periods of time before learning this nuance, and one day we think we broke our radio or fluffed a setting somewhere....
Likely he is using an audio to bluetooth sending unit. Many modern hearing aids
can pair with a bluetooth audio device. [real]
Me, more old fashion; I just feed the audio out to a modulated Tesla HV coil,
and the resulting "audio" is received via the bi-metal (Gold & Mercury) filling in
my tooth :-) [joking, or a lame attempt]
- 328 Community Topics
- 593 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 396 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 158 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 872 Genius Products
- 311 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 438 Remote Operation (SmartLink)
- 135 Contesting
- 721 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 942 Third-Party Software
