SmartSDR v2.6.1 lower audio on Slice B
Ken - VE5KC
Since upgrading to ver 2.61 I find that the audio level is much lower on Slice B. All settings are the same on Slice A & B. DAX is not used or running. This is not due to the received signal strength. It is obvious even with background noise & no signal. Both slices tuned close to the same frequency. The SmartSDR upgrade was done from V. 2.49, following all instructions closely. Everything else is working fine. Flex 6400 using latest version of Windows 10. 73.. Ken.. VE5KC
This is likely beeing a known bug... If you are using the built-in equalizer it's not used by slice B, unless you toggle mode and then back again, i.e go from CW->USB->CW.
Thanks Lasse.. That answered the question. Not a total solution but a way around it. Another one to add to the SmartSDR list of quirks. 73.. Ken g VE5KC0
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
